The intake is available now and special pricing is available for the Nico Folks!!AEM has accomplished incredible technological advances with their Electronically Tuned Intake (ETI) technology. The great news for 370Z enthusiasts is that a new ETI Cold Air Intake System is now available for the 2009 Nissan 370Z (part number 41-1001P).
To match up to the VQ37’s dual throttle bodies, the 41-1001P is comprised of dual mandrel-bent aluminum inlet tubes. Each highly polished 2.75-inch inlet tube originates at the throttle body and routes to the left and right wheel wells. It is in the wheel wells that DryFlow performance air filters are mounted to each inlet tube. The oil-free DryFlow technology is very durable and easy to clean. To take the filtration properties of the DryFlow performance air filter even further, AEM offers Filter Wraps that are manufactured from durable micro-screen materials that are pretreated with a proprietary hydrophobic process. AEM filter wraps repel water splashes and extend the filters service life. For the 41-1001P air intake system, AEM Filter Wraps are available as a separate accessory (part number 1-4000).
In order to clear enough space for the DryFlow air filters, AEM includes a custom designed windshield washer fluid reservoir with each 41-1001P air intake system. Each 370Z air intake system also includes two pre-programmed ETI modules. Both of the 370Z’s Mass Air Flow (MAF) sensors plug directly into an included ETI module, which are specifically programmed to read the proper air density data. The result is more horsepower and torque gains.
In the case of the 370Z, the VQ37 engine responded well to AEM’s ETI technology. The 41-1001P cold air intake systems improve the 370Z’s power output from the stock baseline of 241 hp to a peak of 250 hp with the intake installed. In addition to enhancing the peak horsepower performance, a maximum gain of 9.67 horsepower was also recorded at 7,100 RPM during AEM’s testing. As seen on the dyno graph, a vast improvement is made from 6,600 RPM until the VQ37’s redline.
PM or Email me for price quote.
370z AEM ETI
