Carl H wrote:knock sensing is good for a blinky light on the dash telling you that the pistons are currently in the oil pan.if you give the block an nice whack with a wrench near the knock sensors you should see the voltage spike.
Good knock sensing isn't like that, plenty of OEM vehicles can sense knock long before it ever hurts anything seriously. But yea for most standalones it is pretty s***ty and unreliable.
sepulchralx wrote:
Nothing is wrong with the timing light and where I hook it up, I think I'm supposed to set up the light for the wasted spark. I was a little confused when I called AEM. They said to lock the aem at 15deg and zero the light. They also said something about revvign the engine to 3000rpm and setting it to zero. They were kind of unhelpful, anyways I might just use the old non-display light.
You are taking what I said wrong. I'm not saying your light is bad, but possibly whatever way it is configured.
AEM is correct. You should be zeroing your light if it has configurable advance.
Then you go into the AEMPro program connect to the ECU and there is an option to set your ignition timing.. I don't remember exactly where it is, but it is in one of the menus on the top. Set it for something like 15, so that the AEM is running a static 15* of timing, and then with the light rotate the cas until it reads 15* on the crank.
