480sx »
https://forums.nicoclub.com/480sx-u50548.html
Mon May 07, 2007 5:26 pm
AEM EMS obviously is a hard core tuning system, but then again so is Megasquirt. However, with the aem unit its a direct plug and play. It also costs over a grand...
Im not gona lie, megasquirt is no cake walk. Wiring it up was strait forward, but extensive and time consuming. However thats the easy part. I just got mine running, and tuning it is quite the learning experience(that im still in the middle of, BUT SHE RUNS! ^^) Do alot of research before you go with it though. For your first tuning project im gona have to say MS might not be for you, again, its really extensive. Also, im fairly confidant that if you took your MS powerd turbo car to a tuning shop they probably wouldnt know what to do with it. Its not a widely used tuning system... I kinda feel like im really far out on a limb with it so far. DIY auto tune has the best customer service i have ever dealt with, but still, apart from them i feel like im all alone. It all depends on your set of skills, and your confidence level when dealing with cars/electronics.
A piggyback controller will get you into, and past 300 hp with ease. SAFC2 and a data-logging Wideband o2 system is the easiest way to learn how to tune yourself. The main limit of a piggyback controller is the ignition system. A piggyback controller simply cant control your ignition the way you need it to over a certain HP/ boost level. However, again, unless your going for massive amounts of boost/hp a piggyback controller will suit you fine.
Hope this helps
