ultimatuc, VERY nice numbers-- especially at that level of boost. The graph looks really nice... do you have any logs of your AFR and timing though the pulls? I'd be interested in seeing some of your logs in general, maybe we could trade and compare notes?
I know what you mean about the freakin autometer gauges... My cobalt gauge reads 26psi boost while the EMS sees 20-- what garbage. Let me know if you decide to swap them out for something thats actually accurate, I'd like to hear how that goes.
chandler wrote:say you have a little rough spot in second gear mild accell, can you just go in there and smooth it out by your self? or does it always have to be on the dyno?
You can do it on the street, no problem at all. One of my favorite features of the EMS is its incredible logging capabilities. Everything the computer sees, every sensor voltage, timing point, AFR, load reference, whatever-- can all be logged and graphed out in any way you like. Finding a rough spot or whatever in 3rd would be absolutely cake. Not only would you be able to simply do a few logged 3rd gear pulls on the street with a laptop, but you can take the data, compile it, overlay it, and find out exactly what is causing your rough spot. ...Then just open up the map, find the cell or area of cells that is causing your problem, and fix it with just a few keystrokes. This is, of course, assuming the "rough spot" is some sort of tuning issue. It could easily be bad plugs, low fuel pressure, or any number of any other mechanical failures. Still, mechanical failures show themselves in the data logged by the EMS: a lean condition, a timing error, or voltage drop: all of it can be layed out so that even smaller errors present themselves clear as day.
You dont HAVE to have a dyno for anything with the EMS, it just makes things easier because you can artificially create load conditions that would be tough to do consistently on the street. The only thing you really need to use the EMS well is a laptop... and it doesnt even have to be a real nice one.
I should be a spokesman for AEM I swear... but seriously I just love this system so much I cant stop raving about it. Best thing I bought for my car, and I've bought a lot of stuff...
Modified by fiznat at 10:21 AM 5/4/2005
Modified by fiznat at 10:22 AM 5/4/2005
