naed240sx »
https://forums.nicoclub.com/naed240sx-u28231.html
Wed Jul 27, 2005 1:25 pm
Has anyone ever tested this hypothesis? I would be curious to see how true it really is. I do know that aftermarket intakes come with a heat reflective coating, but do not know how effective it is. It would be interesting to do a setup, with thermometers poking into the 2 intakes before the throttle body and look for any differences. Definitely a good point. However, the air put through the intake is moving at very high velocities, and it would seem that it would not have much time to pick up heat from the piping, before being pulled into the cylinders. Also, as the air takes some of the heat away from the inside of the piping, the interior of the pipe would get cooler. Its really hard to make any claims about this sort of thing. The heat from the intake is only going to be able to heat up the intake air a certain amount, so regardless, if you start with colder air, you will end up with colder air. But dont get me wrong, i personally run a SRI and I like it, I just think that better gains are to be had with a well designed CAI
