i agree, if oyu see any gain it is 2mpg tops, it all depends on your right foot more then anything. lately i been driving like a granny, and i already see myself getting more then 30mpg. so it all on driving condition first. if you have a huge lead foot, you wont see very much gain, hell you might see a drop in mpg.XterraVersa wrote:Im my supercharged Xterra I went from ~15 mpg to ~18 mpg after I installed an Airaid CAI. I think the gain was by removing the air flow bottle neck through the stock airbox that was designed for the non SC model. The restricted airflow turned the supercharger into an anchor. Most that have put them on non-sc xterras saw no gain in mpg or seat of the pants HP.
With the Versa, I don't hear the engine struggling for air when you rev it, so probably a very minimal gain in mpg & power.
As for cooler air, the stock intake sucks air from the grill before the radiator. Were does the AEM suck air from? If its from the engine bay, expect a slight decrease in power.
A cheaper solution would be to use a slide in filter & wrap the plastic intake with heat shielding. A slide in foam filter will clean the air far better and is less restrictive than any oiled cotton filter.
You don't NEED to remove the wheel after installing the intake i could see how it would be MUCH easier to remove it. But simply unbolting the connectors holding the front part of the wheel well in you can fit the filter up and through the hole. Also if you call Bob over at versaspeed.com he will help you with anything you need because the instructions that AEM sends to you must be from the first model versa because they have the old battery tie down.proxim2020 wrote:If you can post a message on this board, you can install an intake. There's not much to it. I've removed a ton of stock assemblies and installed the aftermarket most time with no instructions. I believe the AEM intake comes with instructions. If you need more reference, you can always have a look at the FSM. I think the most time consuming part of the AEM intake install is taking off the wheel and the wheel well.
, lol jkJerr wrote:What exactly is all that stuff that you take out and replace with the CAI? Does it affect the A/C at all (CodeRed knows what I'm talking about
its prolly not too much because we are only talking about a 122hp car. the most i can see it going up is ~5-~8lordkemo wrote:So maybe a stupid question...
It seems there are mixed anwsers on if you get better mpg out of the CAI... but what is the horsepower gain and/or torque. Is there some place to read more about it?
Thanks
