Darius »
https://forums.nicoclub.com/darius-u5470.html
Wed Jul 26, 2006 9:27 am
If you are serious about going for 500whp+ and not just blowing smoke because it sounds cool, then you'll have to upgrade your internals for reliability's sake. A lot of aussie guys and u.s. guys now have proven that the stock rods/pistons are only good for about 500 for a short time period. If you're honestly looking for 500+whp, you'll need to have a boat-load of money to replace many other parts other than just a turbo (somewhere around $8,000-10,000). You'll need new fuel injectors, FMIC, standalone ecu, wideband O2 sensor, new fuel rail, fuel pressure regulator, fuel pump, new intake manifold, new head gasket and associated motor work, pistons and rods (forged or GTR), crank collar?, SS oil lines for the turbo, turbo, and a ton of other parts I'm too tired to type out.
To answer your turbo size question, I wouldn't worry so much about hood clearance, but one of my buddies had trouble fitting a large turbo due to the valve cover. The aftermarket exhaust manifolds that you find on ebay are disposable and will break unless they are supported somehow. Once they heat up, the weight of the turbo tends to sag them down and the welds crack. If you have one custom made, it will probably run you around $1000-1500. I believe it is difficult to fit the aftermarket cast manifolds as they were designed for RHD cars and didn't have a steering shaft to deal with, so they might not fit the turbo downpipe easily.
Hope that helps. whew!
