Have you been using the car for track use with the coils or is it just a daily? How do they feel on actual roads?Ace2cool wrote:I would give the Ultra lites an 11/10 for cost/vs ride quality. Stupid flat through the corners, but not harsh at all with the damper on the "5" setting. Adjustments go from 1-10 IIRC. I haven't even adjusted mine for about 3 or 4 years though. Can't remember exactly.
I haven't tracked it in a while, but when I did (Autocross), they were amazing. I was cutting better times in an auto trans TT than M/T C5 Corvettes.vereshchak wrote:Have you been using the car for track use with the coils or is it just a daily? How do they feel on actual roads?Ace2cool wrote:I would give the Ultra lites an 11/10 for cost/vs ride quality. Stupid flat through the corners, but not harsh at all with the damper on the "5" setting. Adjustments go from 1-10 IIRC. I haven't even adjusted mine for about 3 or 4 years though. Can't remember exactly.
With tire pressure at or below 40PSI they really aren't too bad at all on the lowest/lower settings, mostly the car is just more direct and of course no sloppiness of worn suspension. As the valving and/or tire pressures increase however EVERY bump or irregularity is felt, more and more as the settings increase, and the car can become very unsettled on rough surfaces at the highest settings. Therefore the valving is very accurate and allows a very large range of activity and controls possible for different roads/track/conditions. I really wish they also had a rebound damping capability to "catch" the car and control bounce, but that would be for track-only use as it really isn't necessary for normal driving on the lower settings.vereshchak wrote:How do they feel on actual roads?Ace2cool wrote:I would give the Ultra lites an 11/10 for cost/vs ride quality. Stupid flat through the corners, but not harsh at all with the damper on the "5" setting. Adjustments go from 1-10 IIRC. I haven't even adjusted mine for about 3 or 4 years though. Can't remember exactly.
Awesome I got my answer, thanks!Ace2cool wrote:If you're considering racing competitively, go UL. There is a significant weight difference. And when you're talking sprung weight vs. unsprung, there's a huge difference.
EDIT: and if you think about it, you're already dropping that much into them, so why not let it ride for another $250 and get the product you really want anyways? (Or less if you go the GB option.)
