Hello,New to the forums. have to say great page and tons of info.
Before you go here we go again another customer with questions about what tires / wheels will work. I read those post got lots of info.
Here is the advice I am looking for. I have a set of Foose Hornet 20" chrome wheel ( got them for 185 a piece brand new from the manufacture) cant beat that. they are 20x8.5 with a +34 offset. My tires are a Kuhmo Ecsta 245/35R20.I knew I would have to roll the quarters in most likely. I work at a body shop no problem.I have done that and I still get slightly rubbing on really bad potholes or on body flex.I have a few options to go and was looking for some more advice before I decide.
1) have the wheels sent out and have 5 mils taken of the back plate. It would make them a +39/40 offset.
2) for the body roll put in a rear sway bar. Seems like the Stillen is the way to go based on the info I have read? Would I need to put in the front strut bar as well?
3) Also I have clearance for straight suspension travel. I can put load in the rear and quarters wont rub when vehcile is under load. Seems on body roll.Would lowering the vehcile with springs be another option.
Vehicle is a 2005 2.5S. 42000 miles.
Any advice would be appreciated. I have old style honda quarter wheel well moldings covering the metal where I rolled to quarter so no worried about tirs being cut, but dont like then rubbing even slightly.
thank you
