Beth1433 »
https://forums.nicoclub.com/beth1433-u135523.html
Tue Nov 20, 2012 5:12 pm
You guys have helped me discover my battery was the problem after I ruled it out. After advice from the Nicoforum, I've finally got it started when I jump it, but battery isn't holding a charge. I got it out of the bodyshop 2 weeks ago. The same thing happened the last time I had it in the bodyshop. Last time they replaced it for me. It was an 84 month battery. It's been 24 months since they replaced it. I took it back to them. They keep saying battery is fine, and they're giving me the run around about replacing my battery. They say it's testing fine. That's what they said last time, but when they replaced it, I didn't have a problem until they worked on it again. Would my battery test fine and not be? Should I just replace it myself and see if that works?
BTW, the first time my car was in the bodyshop I had $15k worth of work done. This time only $4k, but still they should just replace my freakin battery to pacify me, don't you think. It's also still under warranty.
