Broadfield »
https://forums.nicoclub.com/broadfield-u46569.html
Wed Oct 22, 2008 12:06 pm
I don't usually use PAC, so is there any dip switch settings you may have set incorrect? If not, call PAC tech support.
Do you follow these instructions?
Operation: G35 with SAT button.1. Turn the factory radio on. Press and release the SAT button until SR2 is selected (in some cases, SR1 may have to beselected). Press Preset 1 to enter [Aux 1] or Preset 2 to select [Aux 2]. Preset 3 to 6 will select normal satellite presets.2. Pressing the Mode button on the steering wheel will scroll through CD, Tape AM, FM1, FM2, SR1 and SR2.3. Pressing CD, Tape, FM/AM will exit out of Aux mode, turning off the remote wire.
