Advice on suspension
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
ArgentoReloaded
Car: Nissan Tiida (Versa) 1.8 Tekna
I´m a newbie to the forums so maybe many of you gave the same kind of advice before, but i read carefully most topics and I didn´t find an answer.i would like to stif my Tiida rear and front suspension. Why? I don´t like how the car performance at high speed (+150 km/h) The body rolls and gives bad sensation to the driver. But in my country the roads are not always in good shape so I don´t want to lower the car height (or lower it no more than 10 mm). So I´m considering 2 possible path: change only the shock absorbers for others with 20% stiffness; or change the springs for eibachs and compensate the height variation with a 215/60 - 16" tire/ rimms set.Any advice?
Promise Land
Car: 2011 Nissan Versa
2001 Chevy Suburban
1992 Ford Mustang
The FR Strur bar will really help with the front stiffness and body flex. Springs with more resistance will also help.
ArgentoReloaded
Thks! I´ll try to find it.
Shad0wXCalibur
Car: Nissan Versa SL Sedan
I'm not sure what wheels/tires you have now but I noticed when I switched to better 205 wide tires that I had more control keeping my car in the lane with huge wind gusts at higher speeds.
nissantech171
Car: 07 sl versa
yeah when i drove my versa for the first time on the highyway it was actually scary, the next day i picked up a set of rims and tires and it helped vastly. im running 215/45/17. if your looking for a stiffer ride but not a lower ride height you can upgrade the shocks but its not going to stop body roll too much. i would suggest an upgraded sway bar and links in the front and see how you like it. then if your not satisfied try a stiffer absorber. there are springs out there that have mild drops.
Return to “Versa Technical Discussions”
