Advice on rims =(?
All things Altima Coupe.
fenderpicks
Car: 2010 NIssan Altima 2.5s
Alright guys i plan on getting my brand new set of tires and rims soon.
I currenltly have 19" but i bended one of my rim cus of a pothole!!
So this time im go with 18"
Just wanna ask you guys what are ur opinions on "TSW Rims"? I been doing searches and alot ppl sed the r too soft.
But i personally like their rim styles alot.
And is tenzo and XXR any good?
And what are some good 18" tires?
DJ_B_Easy
Car: 2017 GMC Sierra All Terrain X
I have Tenzo, only issue Ive had is with the taper on the inner bore being machined a tad bit to deep. I have to tape my hub rings to the wheel and install rather than install rings on hub and then install wheels.
fenderpicks
Do u like ur tenzo? Like how they hold up?
What size are the ones u have btw?
beeristasty
Car: 07 Altima 3.5 SE
DJBeasy wrote:I have Tenzo, only issue Ive had is with the taper on the inner bore being machined a tad bit to deep. I have to tape my hub rings to the wheel and install rather than install rings on hub and then install wheels.
Hub centric rings should be installed on the rim.
DJ_B_Easy
I have hubcentric rings, the issue is with how they machined the inner bore of the wheel itself. The outer edge of the rings (I tried 3 different sets) does not sit flush with the outer edge of the wheel, therefore not centering the wheel perfectly on the hub. Here are pics I sent to them to iilustrate, not sure if you can see or not, look at rust lines...
DJ_B_Easy
fenderpicks wrote:Do u like ur tenzo? Like how they hold up?
19" x 8.5", +45 offset.
