ericlander »
https://forums.nicoclub.com/ericlander-u187967.html
Sun Jul 24, 2011 1:19 pm
I've searched through the forums quite a bit, and have found many links to be a lot of help with regards to the EVAP leaks, knock sensor and oxygen sensor. I have also seen a few threads where owners have discussed many of these codes displaying in conjunction with one another - so I'm hoping to get some thoughts both on the underlying cause(s) as well as a recommendation for fixing the issues.
My vehicle is a 2004 Nissan Xterra w/ the Non-SC V6 engine. The vehicle has 127,000 miles on it and has not had any known engine problems. Last fall I replaced the muffler, tailpipe and connecting pipe after the second cat - and that has been all the work required to date. I'm the first and only owner of the vehicle.
I just took the vehicle to the AutoZone where they ran an OBDII check on the vehicle. The following seven codes all came back:
P0138 - Heated Oxygen Sensor - Bank 1 Sensor 2 (HO2S12) Circuit High Voltage
P0152 - Air Fuel Ratio Sensor 1 Bank 2 Circuit High Voltage
P0158 - Heated Oxygen Sensor - Bank 2 Sensor 2 (HO2S22) Circuit High Voltage
P0328 - Knock Sensor - Circuit High Input
P0442 - EVAP Control System - Small Leak Detected
P0455 - EVAP Control System Gross Leak Detected
P1143 - Heated Oxygen Sensor - Bank 1 Sensor 1 (H02S11) Lean Shift Monitoring
I suspect that the issue is worse than a bad fuel cap, however, I will try to locate one immediately and give the vehicle a few days to see if that helps out at all.
What I'd like to do first is replace the fuel cap, pull the battery connections, and drive the vehicle (around town, nothing more than 20-30 miles total) and have the codes checked again to see if any of them have gone away.
In reading here on NICO, it seems that many things are possible, and I'd like to avoid the high price repair of the knock sensor if possible.
Any help, insight or advice on the situation would be greatly appreciated.
Thanks!
