Just looking for some advice on something for my G. I picked up some flexible LED strips from Oznium.
http://www.oznium.com/
I got two 4.7in white strips. they have a 12V and ground wire and I also pickedup a round LED lit ON/OFF switch. The switch has two 12V and one ground wire.
my initial intention was to install them on the fog light delete in the front bumper. I just wanted to see what everyone though about the best way to do this.
A few questions I though off as I was thinking through installation.
How do you remove the fog light delete?
Is there an AUX 12V supply anywhere under the hood, or should I run it to the battery?
Does the ground have to be on the NEG of the battery, or could it be grounded to anything metal?
Where would you install the button?
What would the recommend path for the wires be?
Thanks for the suggestions everyone.
