cmkelly »
https://forums.nicoclub.com/cmkelly-u42608.html
Fri Apr 27, 2007 4:41 am
Welcome aboard! You're going to love the car if you find the right one. With all the recent purchases of "gems" there are still a bunch out there.
You will get a bunch of replies and help on this topic, here are the issues I am dealing with. Keep in mind that all of these "problems" are relativley minor and can be fixed without too much expense. You can also talk the seller down based on them (unless they're a NICO forum member then you have to give them full price ;>)
Power Steering Leaks. This seems to a problem with the age of this car.
Auto transmission sticks in first gear. Again, a standard problem that can be fixed by unplugging a relay in the engine compartment.
Rear Windows that work correctly. The guides are nylon and tend to break causing the windows to go off track. Several fixes are available in this forum as new parts no longer exist.
Convertible Top Replacement. A new top installed is ~$1000. $300 - 400 parts and the rest labor. Several members are in the process of replacing their own tops.
Rust. Look everywhere. I have an AZ car too but notice rust behind the back seat under where the top stows. Also on the top of the front windscreen area.
Timing Chains Upper Guides. These can be removed (and should be) to reduce noise and reduce the liklihood they will damage the timing chain at some point.
Okay guys, what else?
I hope you find the right car and enjoy top-down motoring.....
kelly
