JNM240 »
https://forums.nicoclub.com/jnm240-u395.html
Tue Dec 10, 2002 2:24 pm
Sorry, MS = Mississippi. Theres a shop here in Slidell, Louisiana, but ive heard bad things about them. They do the same kind of work. Look in your yellow pages for machine shop and give a few some calls and see what kind of work they do. Shipping from Massachussetts to Mississippi is going to cost probably half of what the actual machining will be.
Yes, i pulled my whole engine apart and brought it all in peices to the machine shop. I gave him the block, complete head (cam, gear, rockers), rods (with pistons attached, he had to press them off), crank, and main journal. Ive gotten the pistons back, but we are both waiting (impatiently) on the new pistons. Once we get them, he can bore and hone it and i can get it all back together.
Im totally assuming that youve already taken the front cover off? If so, that should have nothing to do with your pistons. However, make sure the distributor is taken out, it should be easier to remove the oil pump drive gear.
