Advice on Brake Pads and Rotors
TaxationLawyer
Car: 2011 Infiniti M56X
Hi everyone. I am getting ready to change the brakes on a 2011 M56X. Does anyone have recommendations on brake pads and rotors? I am looking for longevity. The original pads are supposed to be made by Advics. But I have had great experiences with Akebono pads on other cars. I will probably replace the rotors, as well--easier than getting the original ones resurfaced. (I will resurface the original rotors and store them for the next brake job.) Thank you.
Ilya
Hey there! Most people seem to go with Brake Motive or one of the other eBay kits that you can get for $200-$250 or so for all corners.
TaxationLawyer
Ilya wrote:
Tue Jul 06, 2021 3:17 pm
Thank you Iya, I will look into that option.
wdebow
Car: 2012 Infiniti M37 Base
use akebono premium ceramic pads all the way around. No dust, work great, very quiet.
(Akebono one of major japanese mgf of brake pads.)
wdebow
TaxationLawyer
wdebow wrote:
Mon Jul 26, 2021 4:16 pm
Thank you, that makes sense. I have had great results with Akebono brake pads.
jtversky
Car: 2013 M37x Storm Front Gray/Java Premium/Deluxe Touring Packages
I'm about to replace all 4 corners on my M37x. Going with Stoptech blanks and Hawk Ceramic pads all around. Last time around I went with Stoptech drilled and slotted rotors as well as Stoptech pads. They've been fine for the most part but I have noticed a good bit of vibration on stopping towards the later end of life. Hoping maybe switching from drilled/slotted to blanks will help with that - she's a great car but not a track b**** anyway :-)
TaxationLawyer
jtversky wrote:
Tue Jul 27, 2021 5:15 pm
Thank you. I tried Hawk brake pads on a different car and they have great stopping power.
Saaax650
Car: Infiniti M37
I went with stoptech, drilled cyro rotors all around with Akebono performance pads 2 years ago. No issues at all
TaxationLawyer
Saaax650 wrote:
Thu Sep 09, 2021 3:22 pm
Thank you. Akebono appears to be a safe bet. I have had excellent experiences with Akebono brake pads.
jtversky
Akebono definitely makes a great product - they are the OEM sport brake manufacturer. As a follow up to my previous comment, i've had my new brakes installed for about a month now and they've been great. I did notice some material inside the grooves of my outgoing pads, which I suspect was the cause of my vibration - either that or a warped rotor. Braking has been solid and smooth since putting on the new pads/rotors though. Very happy with the setup I put on.
