I'm looking into these rims for my 95 s14, but I have some questions for the wheel experts or anyone familiar with the set up.
At 5zigen's website, the s14 is listed in 17in 8.5w for the front and 17in 9.5w for the rears.
http://www.5zigenusa.com/w_pracer_gn.htmlI just want to make sure I won't have any clearance issues. I'm currently running tein HE coilovers with a slight drop with mild if any camber. I entered the stats into an offset calculator and came up with these results:
FrontThe clearance from stut housing to the inside of the wheel will be 7mm LESSThe outside edge of the wheel will EXTEND an extra 43mm
Rear Your new wheel will have the following chracteristics:The clearance from stut housing to the inside of the wheel will be 36mm LESSThe outside edge of the wheel will EXTEND an extra 40mm
Does anyone know how accurate these calculators are? I would like the rim to be more flush with the fender than the current setup, but don't want the rims to stick out.
Thanks for your time and any advice you can provide.
