NJGuy »
https://forums.nicoclub.com/njguy-u191160.html
Mon Oct 06, 2014 7:41 am
If you're used to DIY maintenance for your vehicles, I don't think you should be afraid to take on any of those little projects individually. I have found that the EX is pretty straightforward to work on from a maintenance perspective. And if you don't have enough time to do everything yourself, any competent mechanic should have no issues taking care of each of those jobs you listed.
If I had to recommend an order of importance for the services, the list would probably go something like this:
1. ATF
2. Brake fluid
3. Rear differential
4. Coolant/anti-freeze
5. Transfer case
6. Front differential
7. Serpentine belt
I've done an ATF drain and fill and changed the transfer case fluid, and posted a thread about it here. I haven't gotten to the brake fluid, differentials, coolant, or serpentine belt yet. An ATF drain and fill only replaces about 1/3 of the fluid. The ATF might also be able to be fully replaced via the cooler line through a fluid exchange (flush) machine. I went with the drain and fill method because according to the factory service manual, you're supposed to use the Nissan Consult III software to check the ATF temp and match the fluid level on the dipstick accordingly.
For the 2008, Infiniti calls for Nissan Matic-S or Matic-J fluid for the transmission. They also call for Matic-J or Matic-D for the transfer case. The general consensus here is to stick with the Nissan fluids, but I personally might try an aftermarket fluid in the transmission next time; I already used one in my transfer case. Infiniti also calls for the Nissan Long Life anti-freeze (or equivalent, which is not specified) for the cooling system. For the two differentials, I've noticed that some Infiniti owners prefer the specialty synthetic lubricants made by the boutique fluid blenders (Amsoil, Royal Purple, etc.). However I believe you can use anything that meets the 80W-90 GL5 gear oil spec in the differential units.
I've put together a list of notes for myself on most of these maintenance items. If you want it, let me know and I'll send it to you via PM.
