audtatious »
https://forums.nicoclub.com/audtatious-u2438.html
Wed Aug 08, 2012 5:52 pm
Some say you should consider replacing the water pump with each timing belt replacement. You have a timing chain that is lifetime so there goes that.
If the water pump is leaking, weeping, or making noise then it's time to replace it. Otherwise I would not worry about it unless you have some issue that may point to the pump.
