Rev_D21 »
https://forums.nicoclub.com/rev-d21-u4222.html
Sun Mar 14, 2010 1:00 pm
Red is more than enough. I used gray and it's still dry. If you moved the crank off TDC you will need to reset it. From there you can reinstall the dizzy and oil pump. This is crucial, if you are off a tooth it will not run right.
