Advice for my 1981-2 180b
Here you'll find topics regarding the Datsun B210, 310, 610, 710, 810, 1200, and lots of other models - All are welcome!
sehs33
Car: Datsun 180b
Hello everyone, I am new here and I am honestly not sure if this is the right place to ask for help, in case it wasn't I will appreciate it if a mod moved this post to where should have been started.
I have a 1981/1982 Datsun 180b, the engine burns almost the same amount of motor oil and fuel, and there's no way it can be fixed. The carb is also screwed, so I can't reuse either.
I want your help to suggest a proper replacement for the engine, I am not into rallying, I am just looking for something economical that wont require a fortune to be installed/repaired. I can only go +-20% of the current engine's volume in order to be able to license it (authorities laws) so I can only install motors between 1400 cc and 2200 cc.
My other question, is there anyway (that is financially reasonable) to turn this car into front wheel drive? Just a question, I love it being rear wheeled, but I always wondered if it is possible.
I appreciate your help and I apologize if I am posting in the wrong forum.
Thanks in advance
zanvour
Car: datsun 180b sss
its good to see someone has a 180b/610 over there.
as for engine, i'm not sure, i still have my original one, but i'll have a look for you.
i would love to see some photos of your car.
sehs33
Car: Datsun 180b
Thanks for your reply zanvour; here are some photos I just took:
Interior:
The poor engine:
Carburetor (bad image, it's under the air filter):
Chassis plate:
Help please
sehs33
Car: Datsun 180b
Thanks a lot of your reply MrZed, since it is hard/ costy, I guess this rules out the idea for me.
Any suggestions regarding suitable and economical engine(s)? Thanks in advance.
jaimesix
Car: Datsun 710 , Datsun 610 , Datsun 1200 p/u
May I ask why would you want to go from a preferable and top performance preferable rear wheel driven configuration to an inefficient and lower performance configuration as a FWD?
As engines, you can start with rebuilding your own motor. If you want to swap and do all the adaptation/electrical work, you can add a Nissan SR20 engine, a Nissan KA24, a VG30, etc, there are options for whatever you are looking for, from a mild transportation, through street performance all the way to racing engine.
Jaime.__________________________________________________
chriskapinos
Car: 83 datsun 200sx, 88 200sx ka24e
jaimesix wrote: May I ask why would you want to go from a preferable and top performance preferable rear wheel driven configuration to an inefficient and lower performance configuration as a FWD?
the sr20 is the only option here for him, cause of his restrictions, i would also recommend a ca18de(t) they are fairly cheap, and plentiful.
Mr1der
wouldn't it be more cost effective to just rebuild the L in it?
bibin
Car: Datsun 180b sss coupe
I have the orriginal carburator but I'm in Serbia!!!I dont know how I can help to you
sehs33
Car: Datsun 180b
Sorry for grave digging this post, but I also had it posted in another forum and got several questions about what I did:
- Unfortunately I couldn't find the exact engine in an acceptable condition
- I am aware it would not have been cost efficient to convert it to a front wheeled car, but I was only curious if it is possible
- I replaced the original 1.8L with a better condition 2.0L engine from the same type which needed maintenance (did that) and although it was ok but it wasn't that strong
- I ended selling the car ~September 2010 and got me a 2007 front wheel :( drive car
Sorry again for grave digging this post and thanks for the help guys...
Return to “Other Datsun Cars”
