kingtal0n »
https://forums.nicoclub.com/kingtal0n-u29036.html
Sat Jul 02, 2011 11:55 am
I Dislike electric fans in general. The oem electric fan on the radiator is fine, but replacing that simply reliable clutch fan with a pair of electrical units is grotesque. I have had several bad experiences with them, sure I will share;
#1 I owned a set of FAL unit from flex-a-lite on a Koyo Copper radiator, sr20. The car ran perfect for years like this.
When I SOLD them car, however, the new owner desired A/C. So I added the compressor, wired everything up, filled the system... and it had A/C. But I never drove the car around with the A/C on, I Just handed the new owner the vehicle. Well, a few days later the headgasket pops. He was driving on the highway with the A/C on in the florida heat, the temp gauge went up but he did not notice. Apparently the twin Flex-a-lite fans could not keep the engine cool with the added strain of the A/C. This would not have happened if I had the OEM clutch fan in place.
#2 I had a set of FAL flex-a-lite fans on another SR20 with the adjustable relay unit. Simply enough, the relay was not designed with the power draw of the fans in mind, because it simply burnt up. I opened the black box to find them toasted, after of course the car began spewing coolant while idling in a parkinglot.
I suppose if you consider both of my bad experiences are with Flex-a-lite fans maybe I should just be discouraging the use of those instead of all electric fans. yes they have a place, a good reliable pair, with the proper relay/wiring, that does not strain either themselves or the cooling system or the electrical system... ok, this is what we want.
IMO its easier and perhaps safer to maintain the OEM units, certainly easier.
