advantages of iron calipers over aluminum?
chmercer
is there a reason why the 30mm iron calipers are preferred over the aluminum ones, regarding the 300zx brake swap? i thought aluminum was lighter and dissapated heat faster.
erich
Yea, cast iron calipers are heavier, keeping your car in firm contact with the ground.
llamabeta
Concern of warpage during hard braking is what I understand. Our cars are far lighter than a 300ZX though and the stress that would be seen is less. Aluminum calipers are going on my S13. ;)
C-Kwik
erich wrote:Yea, cast iron calipers are heavier, keeping your car in firm contact with the ground.
Actually more unsprung weight keeps a tire less firmly planted. Adding any weight of course puts more weight over the tires, but the fact is not only does more weight not put a proportianate amount of grip, but more unsprung weight means the springs and shocks must work harder to control the movement of the suspension. Say you hit a bump in the road. The suspension is pushed up towards the chassis. The heavier this weight is, the more resistance is needed from the spring and shock to slow it down. And the heavier the suspension is, the more the tire and wheel will not want to be pushed up towards the chassis in the first place. If the spring and shock can not slow it down sufficiently or as well if the suspension was lighter, the car will start to drop back down towards the road and more of the initial bump will be transmitted to the chassis. So the solution would be to run a stiffer shock and spring, but then you have to contend with giving up ride quality, especially on the initial bump.
But to put it simply, less unsprung weight is better. And looking more at a over all picture, less weight in general is always better.
erich
That was a joke.
book-ends
Car: ???? Nissan 240SX coupe S13
lol..........................that's funny........
Scott McLellan
I have aluminum on my 95 and they aren't "warping." Go with the aluminum. I also painted mine red and then used a sanding block to sand the Nissan letters which makes it real pretty. Only thing I can think of is that the threads are easier to mess up. Just be careful not to over-torque or cross thread something and you will be fine.
theronin
the aluminums work just fine for our cars. dont let anyone tell you differently.
