Project240 »
https://forums.nicoclub.com/project240-u5974.html
Fri Oct 17, 2008 5:24 pm
It's not going to make much of a difference. Some even argue that it can be detrimental; the divider plate won't completely separate the exhaust and wastegate flow since it doesn't connect to the turbo, and can create a pressure differential. The only way to ensure that they get separated completely would be to weld the O2 housing onto the turbo and weld the divider between the wastegate and turbine discharge, which would hardly be worth the trouble.
