and there's more.... lol
Here's some terms and their related explanations:
1. Boundry Effects: Sub placement in respect to the resistive boundries of the vehicle can effect loading. Proper loading in a vehicle can yeild as much as a +6db increase in acoustic power. That is equivilent to 4 times the applied electrical power. The benefit is limited to frequencies where the distance from the acoustic center of the driver to the boundary is less than on tenth of a wavelength. Example of boundry effects: Fill a sink with 4" of water, drop a little ball in the middle and watch the waves spread out evenly. Drop the same ball near a corner and you will see the waves are of a greater amplitude as they spread out.
2. Propagation vs. Modulation: In order to hear set frequencies, we must be able to sense the changes in air pressure. Since sound propagates (moves) at a fixed velocity, the distance between the source and the listener must be at least one wavelength. Propagation is the distance a soundwave travels during one period. As a reference, a 20hz soundwave requires 56.6ft and a 100hz soundwave requires 11.32 ft. Due to the small confines of a car, we are unable to hear the full tone of all low-end freguencies (now you know why vehicles with sub systems can have such a nice sound outside of the vehicle). In car audio environments, lower (longer) frequencies are perceived by uniformly modulating the air mass within the listening cavity. This ability depends upon a proportional relationship between the size and excursion capability of the driver(s) and the volume of air inside the vehicle (sufficient volume available for the sub). Ever been in a vehicle that sounds better with the windows cracked? Not enough interior volume for the subs.
3. Coupling: Modern recordings are normally mono below 100hz. When designing a sub system utilizing multiple drivers, efficiency can be maximized by positioning the drivers as close together as possible and by designing the enclosure such that pairs of drivers share a common cavity. In this configuration, efficiency may increase by as much as +3db and with the mono signal, will yield optimum wave propagation.
Properly setting up a system can be a time consuming process. Unfortunately, due to limitations in the environment, sub placement can be limited which will limit output. Hatchbacks are definately the better environment over sedans (my Probe rocked with the same setup I have now in my Maxima).
So, on top of proper enclosure design, properly building/bracing the enclosure, properly connecting the subs (phasing), level matching the components, frequency matching the components, setting gains, setting up the sound stage, and verifying ohms, you now get to play around with sub placement to achieve the greatest gains
