Advantage of solid pivot or recommendations
NightRyderNy
what is the advantage of installing the tomei solid pivot (lifter) system over the stock one? is it worth the money? would it be recommended for a high 10sec buildup? what exactly does it change and how does it work? Difficulty to install this system?
PS. i have a blacktop s13 motor
Nismo_Freak
Car: 89 Nissan 240SX
You have a high 10 second SR and you don't know how the engine works... ?
Turn many wrenches?
NoStickers
Car: 1991 240sx w/ sr (RIP)
1989 240sx w/ ka
1996 240sx donor car (coming soon)
Nismo_Freak wrote:You have a high 10 second SR and you don't know how the engine works... ?
Turn many wrenches?
You're such an ***. He didn't say he had a 10 second car.
NightRyderNy wrote:what is the advantage of installing the tomei solid pivot (lifter) system over the stock one? is it worth the money? would it be recommended for a high 10sec buildup? what exactly does it change and how does it work? Difficulty to install this system?
I'd love to answer your questions but I'm not too confident in what I know about the topic.
straightedge
Car: s13 hatch
the tomei solid pivot changes the lifters from hyrdaulic to mehcnical. mechanical lifters are more reliable for high rpm operation and usually stronger but they are high maintainance ie: keeping valve lash clearences within specs. hydraulic lifters are like the ronco rotisserie. set it and forget it, they adjust themselves.
