Peabody »
https://forums.nicoclub.com/peabody-u10351.html
Sun Oct 15, 2006 9:41 am
I got a light and it was so high it was way off the scale. I would say if the scale was 2 times the lenght it would be at the end of it. I guess it was at 40 if that is possible. I could not get the idle to go any lower then 800 rpm's so I am not sure if that would make it read high. I also did disconnect the TPS.
What is the highest you would say for max power and the best mileage? I have used 93 octaine for the last 16 years so I do not mind spending the extra money if I can advance it and I get some gain.
I also bought a new computer in 1992 from a company that is out of business that had a very agressive map and they said I had to use high octaine gas. The bad thing is that the stupid computer does not have any lights so I cannot pull any codes. I had to send my factory back for a core credit. It cost $800 in 1992 and did make a bid difference in HP. It said it would raise the stock 140 or 150 I forgot what was stock for 1990 to 170 without any changes. I know the 91 stock HP was 155 and I could take my friends 91 by a 2 car lengths. This is on a stock motor. Now I have a header, 2 1/2" exhaust without a car, air intake. Sorry I am going off the subject.
It looks like the timing was always in this position for years becuse of the marking. I have over 150,000 miles on the original engine and never had any problems and it still runs great but I do have a high idle I am trying to get down. A friend installed the new computer and I do not know if they might have told him to set the timing that high.
So what should I do - set it a little higher then 20 or leave it where it was? I will go for a drive with it at 20 and see how it feels.
If it seems like it lost power what would be the highest I could go with the timing?
THANKS
