Un4Scene »
https://forums.nicoclub.com/un4scene-u44812.html
Sat Aug 05, 2006 9:18 pm
I didn't bother to see what the links are too, so I apologize if I'm repeating anything you've already learned. But in my experience when diagnosing an engine ignition system on a scope the technician doesn't generally look for specific numbers. There are a few shortcuts you can use to check things even if you don't have a scope. But when a scope is used it's usually just to compare the readings between the cylinders. I'm no electrical wizard, but I'm guessing thats where the proprietary automotive testing equipment comes in. I've used a hand held Snap-On unit and a full size shop diagnosis computer, and both of them had special leads going to the distributor or coil wire (to tell when the the coil is firing), and to the plug wire for the #1 cylinder (for timing measurment), and to to the sparkplug wires (to tell the strength of the spark). The leads are basically just a clamp that measures the electrical feed passing through the wire it's clamped on, so I doubt you could even get an accurate measurment since it's reading through heavy insulation and shielding. There are different systems that require different types of leads as well, (curse Ford and their damn Triton engine!) but I've yet to see them on a Nissan. Once you get the cylinders showing on the scope you compare them to one another. Most of the time any problem will be obvious. It gets a little tricky sometimes if, for example, you have a cylinder misfiring at random, in which case it may only show on the scope when it misfires. The old Nissan VG30 motors were particularly known for bad ignition coils And the easiest way (that I'm aware of) to find out which one is bad is to disconnect 1 plug wire at a time and test drive the vehiole till you find one that makes the vehicle act differently. Thats a fairly unique problem though, since often times the coil would act perfectly till the engine was under load. Ahh, enough rambling. I hope this helps answer your questions.
