advance timing on a s13 redtop sr20det rwd
scraper654
what is the correct degree to set the timing on and do u plug in the tps sensor with the engine on or off
scraper654
what is the correct degree to set the timing on a s13 rwd det and do u plug in the tps sensor with the engine on or off after getting the required timing
scraper654
what is the correct degree to set the timing on a s13 rwd det and do u plug in the tps sensorwith the engine on or off after getting the requiried timing
180fan
Car: 89 fastback
15 btdc. unplug the tps before timing, with the motor off.
scraper654
do u plug back in the tps sensor while the motor is on or off after achieving the requiried timing
scraper654
scraper654
180fan
Car: 89 fastback
after
scraper654
what are some things to do get your det up and ruunning
180fan
Car: 89 fastback
what issues are you having?
