advance auto oil pan's gasket
RagingPanda
Car: 78' 280Z
I ordered oil pan seals, front and rear, but it also comes with regular gasket. Do I toss them aside and just use liquid gasket or use them with liquid gasket on both sides?
Secret squirrel
Car: 1990 240sx w/ ca18det
i bought a kit from napa...and i ended up replacing hte front and rear seals and using liquid gasket. It says to use liquid gasket in the FSM
SS
Not_a_sr
Car: 90 ca18 pwrd 240sx FB
advance has this stuff in a aerosol can called "the right stuff". it's made by permatex. the stuff is like glue once it sets, it wont leak, infact it bonds the pan to the block so well that i bent the hell out of the pan trying to separate it when i had to take it apart.
Secret squirrel
:thumbsup" to permatex...we had a guy come in and demo a bunch of **** at school. quality product
SS
float_6969
I tried using the cork gasket that comes with the felpro gasket and it seeps oil out of it on the exhaust side. If I had to do it again, I would just use the rubber end seals and RTV like the FSM says.
biosehnsucht
FSM Knows Best
float_6969
You'd think I'd know better....
nocwage
On the subject of gaskets..Do you guys buy new gaskets for the valve covers or do you RTV it?Mine is leaking a bit near the back
