I have a set of Super Advan SA3's but just wanted to verify a few things on them. Please correct me if I'm wrong.
There are four 'sections' with information either cast or stamped inside of the hub - in the recessed sections.
First Section:SA3-16-1
Second Section:16x7 JJ 32
Third Section:620 KG
Fourth Section:(read as fractions)A / 19 9/64 LO
If I am interpreting this correctly, they are 16x7" wheels with a +32mm offset.
I believe the back-spacing is 5.00" (measured with a digital caliper)
Will these wheels clear Z32 TT (30mm) calipers?
Does anyone know what the 'Fourth Section' is referring to?
