Advan Rg1 wheels on a S13
myS13wantsaVQ35
Car: 1990 240sx / 1997 2dr Tahoe
I just bought a set of adavn Rg1(s) for my s13, beside the five lug conversion,what is must be done to make sure these wheels will fit? Specs 17x9.5 frount and rear 14 offsetWill use Jic coiloversWill use 20mm fenders in frountwill use 30mm or 50mm in the back Thanks
myS13wantsaVQ35
any one?
AmoebAssassin
Car: 1991 Base fastback 5spd, black
You probably are going to need spacers if you want to be hella flush with those big over-fenders.
I'd stick with stock fenders, and a healthy pull. I've seen 18x10 +20 fit under stock fenders with a pull, and those 17x9 +14s will not extend out as far as 18x10+20
Just run decent camber, and pull your stock fenders.
Oh, you're also going to have to hammer some pinch seams on the chassis flat. Other than that, those wheels will fit pretty easily.
myS13wantsaVQ35
thanks
myS13wantsaVQ35
I sold these wheels
