adrians s13, pic request if you please...
gumby74
For some reason or another the fitment database sticky is pulling up blank. However, I have seen a couple of posts showing your car with, what appear to be, white Professors or Works. Would it be possible to see a couple of profile shots of your ride if this is indeed the case?
I have a set of 17" Competitions that are similar enough in spoke design that I am contemplating having powder coated white. I am just a bit perplexed in regards to polishing the lip or going full color. My car is also a red hatch with a black roof, so IF it would not be too much trouble I would appreciate it.
I considered black, but there are enough black wheels out there.
adrianfromthecastle
Car: 1992 Nissan 240sx
theyre ssr professor sp1's btw
Clawhammer
I'd hit that.
gumby74
Outstanding sir, I really appreciate that.
adrianfromthecastle
anytime
94_240sx
Car: 94_240SX
adrians_s13 wrote: theyre ssr professor sp1's btw
Gorgeous. Wheel and tire specs please....
I wish I can come over there and take care of that rear valance. You will like my work.
adrianfromthecastle
17x8/9 +24 w/ 10mm spacers all around making it effectively +14
that rear valance was just test fitted... I took it off because the place I got my muffler done at (i just had a can) made it at such a stupid angle that I can't fit my driverside on... I still have to get it redone...
Black on Gold
Adrian, im just curious to see your other wheels you've had on there.
adrianfromthecastle
Black on Gold wrote:Adrian, im just curious to see your other wheels you've had on there.
just your average enkie mesh 92's...
I still need to rehost the pics... but I can't find the original pics
I forgot where I saved them..
slik_s13
Car: 1990 nissan 240sx hatch back
off topic kinda.. but what tires sizes are you running?
adrianfromthecastle
slik_s13 wrote:off topic kinda.. but what tires sizes are you running?
its in the wheel fitment database stickied up top.
I mean, I could just tell you... but I'd like that thread to be a bit more utilized ykno?
Black on Gold
It sure does.
Once i do the brakes i'll have to make a post in there.
adrianfromthecastle
Black on Gold wrote:It sure does.
post up right now fool. Brakes have nothing to do with wheel fitment, lol
slik_s13
lol. how funny.^but yeah i checked it out aswell as posted up my hatch wheel fitmment.utilized indeed. check it out!
adrianfromthecastle
I saw
Black on Gold
I just want to show everyone they clear Z brakes thats all. I'll snap some pics tomorrow and post them up.
Kalypso
what lug nuts are you using adrian,
and how much did your professors run you,I want some maybe 17 x 9 +15 all around. but I havent check prices lately.
gumby74
If that small hole is any indication, I would guess 5Zigen.
Kalypso
they look really nice... but I need an alternate to spending 150$
gumby74
Thats why I went with the Vision Motorworks lugnuts off EBay. They are $50 shipped, and constructed from the same alloy.There are 2 things to remember about aluminum lugnuts one is the torque. I torque mine down to 70 ft.lbs. and I remove my wheels every 4 to 6 weeks for cleaning. The second is to use a dab of anti-seize on the threads. The lugnuts and wheel studs both expand and dissipate heat at different rates and this is where potential issues occur less so than over torquing. I have yet to have any issues. Except for one time that I had to pull into a Firestone for a flat. The monkey used the air gun to remove the lugnuts after I specifically instructed both he and the manager up front not to. I bought a new set that same night.Also the color holds up extremely well. I have seen the 5Zigens begin to fade within a years time, mine still look almost new. Minus scuffing from the socket.Another option at the same price will be the Muteki SR 48's. I really like these because they are NOT aluminum. I believe they are chrome vanadium steel and only come in black and that neo chrome finish used for Project Kics. Sheck 'em out.
adrianfromthecastle
yeah.. they're the pro racers. And Gumby's right, they do tend to fade after awhile... but only the non locked ones. For some reason, the locked lug nut doesn't fade... lol
either way, I got the whole set brand new for $60, so I can't really complain
I'm still deciding on what nuts to use next... aluminum nuts aren't really made to last forever
gumby74
I agree. That's why I picked up the Muteki's. They are not as chunky as the others though, running a.....17mm tool to remove.oh well, what are you gonna do?
Kalypso
^ thank you, thats what i need
the open lugs expose stock studs to the elements, I worry that mine will rust over time if they arent closed.
adrianfromthecastle
Kalypso123 wrote:^ thank you, thats what i need
pff... I've seen pics of mutekis rust.
