ok comes the tuning part... car runs well but under any load it hesitates, I think the det sensor is bad, im also going to check a boost leak i might be having. The car still idles like an idiot, I checked the air reg valves and I think the tps might have gone bad too, do you think that would cause the motor to rev up and dip then rev up then dip and stall? When I unplug the MAF, the idle stabilizes and doesnt dip after a higher rev period. Any clues?
edit: Fixed boost leaks, gained boost. Adjusted IACVCVVAC to 800rpm, Stalling issue persists...
