adjustment dial on agx's
NoStickers
Car: 1991 240sx w/ sr (RIP)
1989 240sx w/ ka
1996 240sx donor car (coming soon)
The sticky says to make them face towards the wheel but does it really matter what direction the dial faces?
driftaholic
Car: '91 Nissan RM S13
it doesn't make a difference to the units themselves, but if they're facing the wheels, you have to take the wheels off to adjust them. if they're facing eachother, you don't
schyawn
the bottom mount of the shock has a taper on one side. If you match up the taper to the taper on the car's shock mount, it forces you to face the dials inward. If you don't match the tapers, well, lets just say that's not the best idea. See your FSM for detailed pictures.
NoStickers
1989 240sx w/ ka
So it should force them inward towards the car? The real reason I ask is because I have them facing inward towards the car and about a week after the install I was doing something under the car and noticed a pile of black powder which looked like it was coming from the bottom of my struts. This was my first shock install so does that happen normally? Do I have a problem on my hands? I'm just kinda worried and don't like doing a half a$$ed job. Did I do something wrong? Oh if it makes any difference I havn't been driving the car, it doesn't have the engine in it yet.
WongFeiHung
uhm...I thought the knobs were supposed to face outwards...I can still adjust them w/ the wheels on, just a tight fit...
MOTOP
Car: 04 G35 sedan
Mine is facing outwards, I had a shop install those and I assume they've done it right. if somebody can provide me with some official info that states that those should be inward, I'll go harrass the shop.
offtheline
MOTOP, I dont have any official info, but im about 99% sure that the dials are supposed to face towards the differential.
Grant@tirerack
Car: Auto racing (AMLS, Cart,F1,IRL in that order), old show rods, classic monster and bad sci-fi movies,
I just checked with KYB and yes, they are designed to face inboard so you don't have to reach between the wheel/tire and the damper. There is a slight taper to the lower mount that should be matched. Schyan is 100% correct.
NoStickers
1989 240sx w/ ka
Ok so I put them in right. Thanks guys!
WongFeiHung
Damn, they're backwards....Is it going to hurt anything if mine are backwards? Maybe upset the camber??
fiznat
Car: Grown up :(
yep once again they're inward.. haha... it kinda sucks cause theyre tough to get at to adjust- especially the left side cause you gotta make sure you dont get burnt by the exhaust, but you gotta match that taper on there so I guess thats just how it is.
