Adjusting Versa Headlights ?
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
tata12001
Hi All,How can I adjust Versa ( Tiida ) Headlights ? And could someone take a picture for the adjusting screw because I do not know where is it ? Or tell me where I can found it in the Service Manual ( if it is there ).
Modified by tata12001 at 5:20 AM 5/29/2009
tata12001
29 Views and no answer?!!!Please guys i need to know.
biggie
Doubt anyone has done it, I don't have one to look at to see. Maybe call the dealership and ask if nothing else.
Codelicious
Car: 1989 Nissan 240SX
Jus14 wrote:Well to adjust the beams i put tape on my wall in garage and marked it where the it lined out there is high and low beam adjusters one can be reached by hand on each side the other look real close its diagonally downward toward the fenders i used a phillips screwdriver when you twist it it spins the gear to adjust higher or lower.....both just look like little gears on back of headlights..simple when you figure it out lol
That should help. Found it in another thread.
superskunk
Car: '07 Nissan Versa S Hatch
'06 Nissan Murano SL
get yourself a 10mm socket, and when you look behind your headlight you will see white piece, now in the center of the white piece is a nut, and around it is like a wheel with teeth, this is what you use to adjust your headlights..... hope this helps... if you still have trouble finding it, let me know and i will post pics for you....
tata12001
Thanks so much guys,but could you post some pics ?sorry for bothering.
Andrews Chalmers
Car: Versa '07 SL CVT
Look through the service manual - it is in there some where. Like you - we're just too lazy to flip through it.
Jus14
Car: 97' S14 and 08 Versa
I posted how to do this is one of the projector headlight question but there are about three threads posted so you will have to search it its simple....
tata12001
Thanks for answering mate, but I do really used the search result before, and I did not get the wanted result because it is the worst search feature ever!, there should be an advanced search feature.So please guys , if anyone can help ? do it....
tata12001
Are those the adjusting screws ? and which one is the vertical adjuster ?
Return to “Versa Technical Discussions”
