Meaux »
https://forums.nicoclub.com/meaux-u23660.html
Tue May 23, 2006 5:51 am
I'm sure I'm a little confused here, but knowing the TPS has a dual function...1-"On/Off switch" with pedal released (warmed up at idle)...and 2-pedal "Position".
When I set mine w/ the voltage method, I don't get the "On/Off" function...and I can't get to the .44v either...so, I set it as close as I can get it...
What's more important, Volts, or the On/Off section of the TPS?...Seems impossible to get both parameters set w/ only one adjustment.......I'm I missing something here, besides a Consult...?
I still think I have a bad TPS because of the erratic reading I get when Ohming the rotation of the switch...
I'll be changing the plugs and fuel filter soon, so I'll check it again...
What bugs me is the car seems to change a little (driveability) day by day...1 day it will be near perfect, next day seems sluggish, but not much...Next day perfect...and on and on..
