StryfeS13 wrote:But my questions is, is it supposed to be .46 at wide open throttle, or at idle!? Cause mine is 1.97 at idle, and .46V at wide open throttle. And I can not set the idle or time the car, because it wont idle below 1500. However, with the tps unplugged, all issues are gone.
When was the last time you cleaned or changed your IAC? Those are known to go bad and can cause the car to idle high. My friends is bad and his car won't go below 1200RPM.StryfeS13 wrote:Changed my TPS, fixed the voltage issue. Got it to .52V @ idle, which is fine. I still cant get my car to idle under 1000 though. This might be because I do not have any emissions?
