adjusting timming
fly240
Car: nissan 240sx
I need helps with adjusting the timming. My timming belt is still stock, last night I open the cover and feel that the timming belt is not very tight and I feel the car has a slow response. I am wondering if any one who done adjusting timming before could help me with any information. thankyou
shedrifts
Car: rb powered sil80
timing belt shouldnt be extremely tight should have some play and i was reading on rb20det.com (i think) that if u reset your ecu your car will adjust timing acordinly to mods and stuff but thats just the cas timing the rest you may wanna check with fsm and see the slackness in the belt first cause two tight and it will snap
Eikon
Car: 71 240z, 93 Supra TT
Hey... an RB in Madison.. outstanding.
grab the timing belt between the intake cam and the tensioner on the way down and turn the belt sideways. You should be able to turn it about 45 degrees.
That I learned from Rob... the guy who owns RIPS in New Zealand.
check the thread about FSM's. you should be able to AIM a guy named spazz on NICO. He has them saved and should be able to get you the pages you need from the service manual.
fly240
Car: nissan 240sx
Hey Eikon..what happen if you grab and turn 45 degree. Will it tighten up. Tell me more about it...
fly240
Car: nissan 240sx
How do you reset the ECU?...
Eikon
First... to reset the ECU... disconnect the battery terminals for a few hours. The lack of electricity will reset the ecu.
Second.. nothing happens if you rotate the belt 45 degrees. It is just a test of how tight/loose the belt is. DON"T Rotate the belt like the engine does. just grab the belt between your thumb and finger and twist it. It should twist about 45 degrees or so. If it's too tight you won't be able to twist it very far. If it's too loose, you will be able to twist it more that than.
fly240
Car: nissan 240sx
when the engine is cool, the timming belt is loose. but when the engine is hot, the belt is tight is this normol for rb engine. any body..let me know how your timming is?..
