Adjusting Timing won't idle below 950rpm
ihatespeedbumps
So I have my IACV screw all the way in, with the tps unplugged and still can't get this SR to drop below 900 to 750 so I can set the timing. Any thoughts or ideas, am I missing something? I already set it by pulling it out, removing the valve cover, and reinstalling it lined up. I just want to make sure its set properly. Throttle isn't holding the rpm back either I adjusted it all the way out, just won't drop below 900.
shift_SRDETuser
Car: 1996 Nissan 240SX SE
ihatespeedbumps wrote:So I have my IACV screw all the way in, with the tps unplugged and still can't get this SR to drop below 900 to 750 so I can set the timing. Any thoughts or ideas, am I missing something? I already set it by pulling it out, removing the valve cover, and reinstalling it lined up. I just want to make sure its set properly. Throttle isn't holding the rpm back either I adjusted it all the way out, just won't drop below 900.
stock cams or aftermarket cams?
ihatespeedbumps
Bone Stock SR.
shift_SRDETuser
ihatespeedbumps wrote:Bone Stock SR.
there is a reset procedure which involves a bunch of plugging and unplugging of the tps I believe it is in the FSM. Find the FSM and you should be good. Or you can unplug your battery cable overnight and then reset it yourself and see if this fixes it.
the converted
Car: '99 BMW M3 6.0
'88 Toyota Celica All-Trac (somewhere in Cali)
'20 Toyota Tacoma
Pinch off the iacv and see where it idles. If it won't get down, you'll have to adjust the throttle stop.
ihatespeedbumps
I loosed the throttle cable all the way and even backed up the throttle stop, still 900, is this too high to set the timing with?
shift_SRDETuser
ihatespeedbumps wrote:I loosed the throttle cable all the way and even backed up the throttle stop, still 900, is this too high to set the timing with?
My sr20det would idle at around 800 rpm with the stock cams -- with the greddy easycams I run it now idles around 1000 rpm. It idles lumpy and fast --- others might chime in but this just the way it goes with aftermarket cams.
ihatespeedbumps
How bad is it to set timing at 15btc idling at 900rpm?
