BackToFrio »
https://forums.nicoclub.com/backtofrio-u271957.html
Tue Feb 21, 2017 5:21 pm
Hi,
2002 Pathfinder LE 3.5L
I'm sorry if this is ridiculously simple and I'm just not getting it . . . I need to replace my throttle position sensor and understand that it needs to be calibrated properly once it arrives. I have found numerous sites detailing how to do this for various other types of Nissans -- including the 3.3L Pathfinder, and they all mention something along the lines of putting my red lead to pin #2 (middle) and rotating the sensor until the voltage is somewhere around 0.5 V DC. I can't seem to find this reference in the FSM for this car.
What I DO see in that section (EC 122-124) are instructions for adjusting the throttle body SWITCH by using feeler gauges, rotating the sensor, and checking for continuity between terminals 5 & 6 of the switch's connector.
I understand that the TP sensor has 2 connectors (throttle position and idle switch). So the switch instructions are there and clear, can anyone help me understand how to adjust the sensor portion?
Thanks In advance.
