Adjusting the TPS?
Dustin240
How do you adjust the TPS? What (voltage)
j-z
Car: 95 240sx
its supposed to be .4 -.7 volts closed and 4 volts wide open. you adjust it by loosening the two bolts holding it in place and then turn till you get your desired voltage.
