Adjusting the timing on KA
Kaioshin1982
Car: Not a 240 =) Thinking of getting one again...
Is there anyway to adjust the timing on a KA motor? If so where and how? Thanks in advnace
fiznat
Car: Grown up :(
base timing? yes... you need a timing light.. point that at the crank pulley timing pin and then (after unbolting the set bolt) rotate the distribuitor counter clockwise or clockwise to retard or advance the base timing.
If you want to change timing at any other point you will need something else entirely...
ILikeMy240sx
Car: SR Power
Oh yea dont forget to hav your car fully warmed up first and unplug your TPS sensor before you measure your timing.
ILikeMy240sx
Car: SR Power
I feel like being a nice guy... here is a write up.
1. Let the engine warm up2. Disconnect TPS3. Connect timing light4. check.. if not 20+-2 BTDC adjust as shown below- loosen the bolts circled then turn it CW to advance CCW to retard5. recheck timing
http://ka-t.org/tech/
click for more info
EDIT: fixed my mistake
Modified by ILikeMy240sx at 12:39 AM 2/11/2005
s13EastTN
Car: 91 s13 hatch, 95 Honda Civic
That picture is missleading. If you turn it clock wise (mounting bolt is closer to the right side of where it mounts too) it retards it. If you turn it counter clock wise (mounting bolt is closer to the left side of the mounts) then its more advanced.
ILikeMy240sx
Car: SR Power
ahh crap... i need more coffee. Thanx for the correction.
I will photoshop
EstoMax
Car: 95 240SX KA-t
94 d21 xe 4x4
ummm disconnecting the TPS huh?
i dont think i did that when i adjusted mine lolwhere do i disconnect it >_< (im too lazy to pull out the fsm )
what happens if i dont disconnect it ? i recently set it back to where it was originally though..
max
ILikeMy240sx
Car: SR Power
if your TPS is still plugged your idle will not be same as getting 700rpm idle with TPS unplugged
Arrow
Car: 1990 240SX SE - SOLD
2003 Kawasaki Ninja 250R - SOLD
2009 Kawasaki Ninja 650R - corner carver
1998 Pathfinder
Also, an important part to adjusting the timing is to realize which 240 you're talking about as far as base timing goes... DOHC = ~20 ; SOHC = 15
Just to put that info out there so nobody reads this thread and happens to mess up their timing.
s13EastTN
The TPS is around your throttle body. I think there are two connections close to it and you want to unplug the...one toward the lower left if I remember correctly. This is all off the top of my head tho, I haven't even popped the hood on my car in a month :X
skydragoness
Car: 03' 350z Touring 6spd
92' 240sx 60k survivor :)
Arrow wrote:Also, an important part to adjusting the timing is to realize which 240 you're talking about as far as base timing goes... DOHC = ~20 ; SOHC = 15
Also, if you advance the timing more than the OE setting, premium fuel is mandatory.
