AS
fazer55t wrote:Alright.. (because I'm new to this)
if I get an aftermarket sub & amp, can I connected that to the stock 6disc head unit?
Sure can! I actually just made a thread about this a couple weeks ago in this part of the forum. You could try to connect everything at the head unit itself, but I found it easier to tap into the speakers. Get an amp with speaker inputs. Tap into the rear speaker wires and run these new wires into the speaker inputs. This will feed the signal to your amp. For your remote wire to your amp, tap it into the radio fuse in your fuse box. This will allow the amp to turn on and off when your car and radio do. Just hook up your sub to the amp, run the ground wire to any point that comes in contact with your chassis (there are some bolts underneath the driver's seat that are great for this), and run the power wire to your battery.
