sherwooa »
https://forums.nicoclub.com/sherwooa-u271084.html
Tue Feb 07, 2017 7:35 pm
Standard specs for an EX35 (2008) are:
Minimum: –1° 05′ (–1.08°)
Nominal: –0° 35′ (–0.58°)
Maximum: –0° 05′ (–0.09°)
so, the op's camber is not terribly out of spec, but it's out of spec to be sure. Not sure if the G37 camber bolts will work as I'm guessing few have tried. But if you can return them, it might be worth a try. the specs for G37 (non sport) camber are more aggressive than the EX, likely because the ride height is also different, but the suspension components are basically the same.
