Adjusting Projector lights on Versa
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
Touch524
Car: 08 Nissan Versa SL 1.8 CVT
Hi! I have installed projectors on my Versa and i can't adjust the projector light beam to go any higher. If you know, please reply!!
[IMG][/IMG]
audtatious
Realize that projectors have a cut-off and will look low until you get used to them. Raising them up too high will simply blind oncoming cars. I suggest you find a friend who has a factory projector based car and line them both up side by side about 15' from a wall to see where your cutoff line is compared to his.
Return to “Versa Technical Discussions”
