ghettoslide »
https://forums.nicoclub.com/ghettoslide-u18248.html
Thu Oct 25, 2007 3:17 pm
Headlight adjustment should be left to a professional, but let me try to explain. On the top of the assembly not the back you will find the screws you are looking for. One is on the left top side of the assembly between the two bolts that hold the assembly in in place ( the mounting bracket ). The other is on the right top side of the assembly a little harder to explain, but in plain site. You will see a oval shaped cap looking thing held in place by two full ( phillips ) head screws. There is a round indention on this cap your screw is in the top right portion of this cap. The screw on the left adjust up and down the one on right controls right and left. Let me look for a pic.
