ITA240SX »
https://forums.nicoclub.com/ita240sx-u6765.html
Thu May 08, 2003 12:47 pm
You're probably not going to notice any difference in "stiffness", since the Koni Sports (yellow) are only rebound-adjustable. The compression stroke can only be adjusted by re-valving the shock. For a street car you probably want the rear shocks set on a softer setting, as this will allow the rear to rotate a little more than the fronts, and keep it hooked up. I don't have any experience with drifting, but I would guess if you want the car set up to drift you would want the rears as stiff as possible, as this would make it a little loose. Any drifters out there who can confirm this?
